 Tytuł: macan s
PostNapisane: 15.11.2017, 23:11
Witam!
taka informacja mi sie przytrafila : No monitoring System Learns a.o. 25km/h"
Co z tym zrobic??
 Tytuł: Re: macan s
PostNapisane: 15.11.2017, 23:24
Witamy na forum, zapraszamy do klubu :)
Tutaj znajdziesz odpowiedź:
System learning
The Tire Pressure Monitoring System begins to “learn” the wheels after a wheel change, wheel transmitter replacement or update of the tire settings. During this process, the the Tire Pressure Monitoring System recognizes the wheels and their locations.
The message “No monitoring System learns a.o. 16 mph (25 km/h)” appears on the multi-function display.
The wheel learning process takes place exclusively when the vehicle is being driven (vehicle speed of more than 16 mph (25 km/h)).
The Tire Pressure Monitoring System requires a certain amount of time to learn the wheels. During this time, the current tire pressures are not available on the multi-function display:
The tire pressure warning light remains lit until all wheels have been learned.
Dashes (-.-) appear on the display for the “TPMS” function.
The required pressures for cold tires (68 °F (20 °C)) are shown under “Fill info” in the “TPMS” main menu.
Position and pressure information is displayed as soon as the Tire Pressure Monitoring System has assigned the wheels recognized as belonging to the vehicle to the correct wheel positions.
Check the tire pressure for all wheels under “Fill info”.
Correct the tire pressure to the required pressure if necessary (differential pressure value “0.0”).
Tire pressure warnings
The tire pressure warning light on the instrument panel and a corresponding message on the multi-function display warn about loss of pressure in two stages (yellow and red), depending on the amount of pressure loss.
 Tytuł: Re: macan s
PostNapisane: 15.11.2017, 23:39
Qbak! Dzieki! Wielkie!!
:D
