PostNapisane: 13.10.2015, 8:30
No proszę po ciekawym ruchu jaki zrobiło Porsche wypuszczając Cayman'a GT4 jest pomysł na Porsche 911R dla mnie trafione w 10....
A new report finds Porsche will introduce a limited-edition model dubbed 911 R in the not-too-distant future.
Billed as a tribute to the original 911 R that was launched as a homologation special in 1967, Porsche's next limited-edition model will be equipped with the same 3.8-liter flat-six engine that powers the track-ready 911 GT3 (pictured). Its output will likely remain pegged at 475 horsepower and 324 lb-ft. of torque but it will be bolted to a manual transmission, a feature not offered on the GT3.
Although further details are being kept under wraps, it's not too far-fetched to speculate the gearbox will be a seven-speed unit. Rear-wheel drive will be the only configuration available.
Don't get the wrong idea, the 911 R won't simply be a GT3 with a stick. It will ditch its automatic counterpart's sizable trunk-mounted wing for a more streamlined appearance, it will ride on skinnier tires and it is expected to weigh noticeably less. In short, the R is shaping up to be the long-rumored driver-focused 911.
If the report is accurate, Porsche will unveil the 911 R online in the coming weeks and the coupe might greet the public for the first time next month at the Los Angeles Motor Show. However, well-heeled enthusiasts who want one might already be out of luck because an anonymous source close to Porsche told Road & Track that the entire production run has already been spoken for.
Read more: http://www.leftlanenews.com/gt3powered- ... z3oQE3w3zV
PostNapisane: 18.10.2015, 13:17
Również wyczynowa wersja, w postaci 991 gt3 R miała ostatnio swój debiut:
http://wyscigi.autoklub.pl/news/premier ... t3-r,64136
Zestawienie wyczynowych 991 gt3 - Cup vs R vs RSR:
http://www.car-revs-daily.com/2015/05/1 ... s-gt3-rsr/
PostNapisane: 29.10.2015, 23:55
Jest już więcej informacji i są też zdjęcia, generalnie 991 R wygląda trochę, jak 991.1 GT3 bez "skrzydła":)
http://www.total911.com/exclusive-porsche-911-r-spotted-testing/
i ponoć ma mieć MT (manualną skrzynie)... i być może legendarnego "ducktail'a", od którego zaczęła się era spoilerów z tyłu w Porsche ('73)
http://www.total911.com/rear-wings-and- ... 1-history/
Darek
PostNapisane: 24.11.2015, 1:01
A tymczasem plotki, ploteczki nt. nowej wersji wyczynowej RSR na 2017:
http://sportscar365.com/lemans/wec/pors ... -for-2017/
Ponoć silnik turbo, chcieliby go wsadzić centralnie (FIA pozwoli? a może jakaś krótka homologacyjna seria produkcyjna?). Wygląda na to, że były plany podmianki 911 na Caymana, ale marketingowo ocenili to negatywnie. I na razie jest szpagat :lol:
